Tee cost of Fullthrottle cam kit is $800. Labor is gonna be about 10-14hrs (depending on the experience of the installer, and if they install a new pan gasket) to do right. Labor cost is dependent on location. Around here, it is $75-125/hr. depending on the shop. You will also need a timing chain, intake gasket, timing cover gaskets (min. 2 probably 3) and to the best job, an oil pan gasket. (might as well change the rear main seal while you're at it, too.) If your cam is flat, then go ahead and have it done. If your cam is OK, LEAVE IT ALONE!!!! There is very little power gain in a cam change, unless you have ported heads and a BIG turbo. There guys running solid 10 second 1/4 mile times with a stock camshaft.
