Roller Kit
KWIKR 1
Fresh custom ground Comp Cams 206/206 ductile roller , New Comp Roller Lifters (#853-12) , New set of K-Motion Valve springs (#K-750) . all parts have been Cryo Treated - $700 Shipped . Thanks .
Cam & lifters
I am interested in your camshaft and lifter setup. How do you think it would work with a stock motor? Is everything there that I need to install in my stock motor? If not what else do I need? What is the best deal you are willing to make on your cam and lifters??
206/206 duration is good choice for a stock engine . I would put in a new roller cam button ,and chain, and maybe a set of different length push rods , depending on what preload you'll get with the pushrods you now have . and I would change the valve springs . so you bascily need a roller button , timing chain , and possibly push rods . PM if your still interested . thanks .
I notice you already have a 204/214 . good cam , I've had it in another build !!! pulls like a freight train . IMO if there is nothing wrong with it leave it in . spend your money else where :)
$625 shipped :) . gross valve lift works out to .521"
