John Larkin
Sublime Master of Turbology
- May 25, 2001
Ok, let me get this straight: In order to roll the wheel opening lips in the quarter panels to gain tire clearance, you use a wood baseball bat as a lever against the tire. Then you roll it along the lip and basically crush it upward, applying downward pressure while rolling it. This is after taking the molding off. Is this correct? And if you want to reinstall the molding, you have to trim it or section the inside edge with some pie cuts, bend the edges to conform to your newly crushed lip and then reinstall?
