Trying to put my motor together after a long time being disassembled.... block was line bored after 2 center steel caps were installed. I was told a .004 didn't fit so I ordered a .002...... well.... other issues caused me to pull the engine out twice.... in 60 miles of driving...... now that that has been fixed... I am re-assembling my 60 mile motor.... The timing chain has about .380" slack...so if you press on the chain where the stock tensioner does.... it moves a total of about 3/8" ..... so I get to looking at my timing set.... and there are no markings on the timing set other than Rollmaster..... obviously there is multiple keyways in the bottom gear....and two dots.... and one dot on the top gear.... and "rollmaster" inscribed into the gear...... but best I can tell.... there is no identifying marks that tell me it is an +.002" gearset.
Anybody else run into unmarked timing gears?
Frustrates me.... because they are very clear on T/A's catalog that say the gears are a matched set.....but yet I have no way to know if mine are actually .002 or not.......
BTW... it is not T/A's fault.... I ordered it from another vendor on here some time back.....but had a T/A catalog handy when I went to look up what set I needed to order next.... IMHO... Rollmaster should have put some identifying numbers or marks to let me know that both gears are .002" line bored gears....
Oh... I didn't assemble the engine initially... so I don't know if there was any slop... or if there was.... how much... I can't say.... I just know now.....that it is too sloppy for my liking.....
