rotor replacement
jsta6
John 15:17
OK, I got new rotors and pads.
Before I start the job, what else do I need while I am there? Some kind of hub seals or something?
Some new seals and some good bearing grease, some disc brake quiet for putting on the pads and some brake cleaner to make sure everything is clean when you are done.
I used the the inner bearings from the old rotors ( if they look ok ) and cleaned them up and regreased them. The new rotors should already have the outer bearings installed in them.
Tarey D.
