mattcsn
- Nov 2, 2018
I'm having an issue that kinda sprang up from nowhere. Under heavy acceleration the car will spudded and miss. It only happens after about 5-10 minutes of driving. Before that the car runs just fine under wot.
After replacing the ignition coil and module the car seems to idle worse. It's better when I unplug the mat but only because it seems to run at a higher rpm.
Plugs are only a few months old and all vacuum lines are also newer and hooked up.
I was considering the crank sensor or cam sensor? But after idle leveling out which maf unplugged I'm confused.
Car is basically stock with hotwire, down pipe and fuel pump upgrades.
Thanks for the assistance.
I have attached scan at idle. BLM seems to be high on idle scan?
Sent from my SM-N950U using Tapatalk
