SignUp Now!Not trying to argue with someone that's probably forgot more about these cars then I'll ever know.
I've checked the accuracy of the Glowshift boost and fuel pressure gauges with other test gauges, but not in the same way. More along the lines of hooking them up in parallel on the car and seeing if the readings matched. My testing, while not scientific, was in the "middle" of the gauge range, and not on the lowest or highest end, where any gauge is more prone to errors. The op asked about budget gauges, and they seemed to be accurate enough for me. Now I'm just talking about boost and fuel pressure. What your videos proved to me is I wouldn't want one for oil pressure or anything that was on the low end, which is where oil pressure is on our cars when they're warmed up.
I'll finish with saying many Thanks for the things you have done for our cars! I've had my TR6 on for a few years now, and while I don't race it that much, I don't worry about ignition problems anymore!![]()
I think im having a similar problem with my 87 GN. I starts and runs but idles really rough. I have to feather the throttle to keep it running until it warms up a bit but then it sounds like it wants to die. I can tell its running very fuel rich by the overwelming flooded smell. a warning light comes on but its the washer fluid light, havent figured that one out by im interpreting it as a service engine light. i can drive it and it smoothes up and runs fine and the light goes out but as soon as i go back to idle it sounds like it want to die and the light comes back on. i dont have a scan tool to pull the computer codes. i did disconnect the battery wire to reset the computer and i tested the tps. tps seems to be working properly. i adjusted it to .44 at idle and it goes up to 4.40 at wot. i think thats normal operating range. i took off the maf to see if it was dirty. i was a bit oily but no dirt or crud stuck to the little wire. the k and n air filter was pretty dirty though. its one of those ones you have to oil before installing........im not sure if thats normal or not. I dont know where to go from here but i need some help/advice from anyone.OK got the IAC down to 68 and it froze, so I shut off the car readjusted the TPS and now the IAC seems to be stuck at 0 and the BLM's have gone back up to 150...does this sound like a vacuum leak?
