next_level
- Jan 29, 2002
soon as i start the car i get a slight tap (sounds like lifter or exhaust)
under a little bit of load and up until about 2800rpm i get the tap, once im up to speed and just barely touching the gas to keep the car moving i get nothing, if i stomp on it i get nothing, i put the car in nuetral and rev it i get nothing...
was thinking it was an exhaust leak but i cant figure out why it would only be under load, unless the motor is twisting just enough to open the leak up more....
i dunno...
cam/crank sensor was supposed to be done in the past 2 years, could it still be going bad?(cant prove it)
motor should have around 40000 on rebuild (cant prove it)
i dunno...
