Aug 3, 2002 #1 M motorhead motorhead mike Joined Sep 9, 2001 Messages 1,181 I am installing my HKS Type-1 Turbo Timer and I need to know: Which wire is used as the RPM signal. To Tach? To ECM? From ECM? Thanks,
Aug 3, 2002 #3 B Black Car Active Member Joined May 25, 2001 Messages 1,032 Behind the alternator on the 86-87 you will find two white wires going into a green connector. This is what you want to use for rpm/tach signal. Gary
