RPO codes!!
Ram
Where can I find a complete list of RPO codes for a '87 GN??
Ram
Thanks for the link but is their a list somewhere for the Regal or GN only.
My sticker is missing and I'm trying to put together a new one,
and that's a lot of codes to go through, most of them I wouldn't have a clue if they should be on a GN or not.
Ram
Ram - that list is for Regals and would be the right list for you
unless the code was NA with turbo (LC2 option)
Frank - your right, the IP address instead of gnttype threw me.
bye, Ed
http://edchapman.tripod.com/cars.html --------- runner up B-5 GS nats 2004
84 T-Type WH1 15.4@89 stock, 87 T 14.1@97 stock, 87 GN stock 399/400 points
I'm talking about the codes all the way to the bottom of the page I think every make & model is included there.
Mine is missing and I'm trying to put one together & some of the examples I see from other GN's have more than is what is listed on the top half of the page.
Ram
Ram,
Here are my RPOs from my GN, decoded as best as I have been able using several resources.
Do you see what you're up against without that Service Parts Identification sticker?
Hope this helps:
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS & DRIVER RECL
AU3 LOCK CONTROL, SIDE DR, ELEC
A01 WINDOW TINTED, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, SIDE
A90 LOCK CONTROL RR CMP, LID, REM CONT ELEC RELEASE
BD1 ORNAMENTATION, EXTR MLDG, ROCKER PNL - DELETE
BS1 INSULATION, ACOUSTICAL PKG
BV8 ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER
BX1 ORNAMENTATION, EXTR FRT END, SPECIAL
BX5 ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED
BY4 ORNAMENTATION, INTR, INST PANEL, NAME PLATE
B19 ORNAMENTATION, INTR, CUSTOM
B24 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
B71 MOLDING WHL OPENING, COLORED
B72 ORNAMENTATION, EXTR MLDG, BELT REVEAL, COLORED
B77 ORNAMENTATION, EXTR MLDG, W/S REVEAL, COLORED
B79 ORNAMENTATION, EXTERIOR, RR END
B88 MOLDING B/S, CUSTOM
B89 ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL
B91 ORNAMENTATION, EXTR MLDG, DR EDGE GUARD, COLORED
CD4 WIPER SYSTEM, WINDSHIELD, PULSE
C01 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 2
C18 ARM & BLADE, WSW
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C95 LAMP, INTR, ROOF, COURTESY AND DUAL READING
D55 CONSOLE, FRT COMPT, FLOOR
D64 MIRROR I/S, RH, SUNSHADE, ILLUM
D68 MIRROR O/S, LH & RH, REM CONT, COLOR
D7I GEAR, SPEEDOMETER DRIVEN; #25524925
E5Z ADAPTOR SPEEDO. DELETE
FE3 SUSPENSION SYSTEM, SPORT
FFL FLINT, MICHIGAN, BODY PLANT 1 (BOC)
GMD GMAD PLANTS (PLANT CODE)
GU6 AXLE REAR, 3.42 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
G87 RING GEAR, 8.50 INCH
J41 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
J50 BRAKE SYSTEM, POWER
K05 HEATER ENG, BLOCK
K09 GENERATOR, 120 AMP
K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC
LC2 ENGINE, 3.8L V6 TURBO
MW9 TRANSMISSION, 4-SPD AUTO (THM200-4R)
MX0 MERCHANDISED TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM, FEDERAL, TIER 0
NP5 STEERING WHEEL, LEATHER WRAPPED
N33 STEERING COLUMN, TILT TYPE
N83 WHEEL, 15X7, CHROME, STYLED
PON PONTIAC
QYZ STEEL-BELTED, RADIAL-PLY, BLACKWALL TIRES (P215/65R-15)
TL6 GRILLE, BLACK
TL8 FLEET INCENTIVE, SM&P CONDUIT CO, INC
TT5 HEADLAMPS, HALOGEN, 2
T43 SPOILER, RR
T47 COMMERCIAL BODY, PROVISIONS, UNION CITY BODY
T63 ALARM, HEADLAMPS ON WARNING SYSTEM
T83 HEADLAMPS, DR, SPECIAL
T93 LAMP, TAIL & STOP, SPECIAL
UA1 BATTERY, HIGH CAPACITY, WET
UM6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS
UQ1 RADIO PROVISIONS, FOR STEREO
US7 ANTENNA, POWER, PAINTED, RADIO
UW4 SPEAKER SYSTEM, 6, DUAL FRT DASH MTD, F/D, DUAL
U12 SPEEDOMETER, DUAL SCALE WITH KILO ODOMETER
U23 CLUSTER, INST, TRIP ODOM
VH6 BUMPER FRT, BLACK
VK3 LICENSE PLATE, FRT MOUNTING PKG
V73 VEHICLE STATEMENT USA/CANADA
V97 VEHICLE PREPARATION, EXPORT
WE2 GRAND NATIONAL
X07
YR1 SEAT, FRONT (CUSTOM)
YS1 SEAT, REAR (CUSTOM)
YT1 BUILD-UP, CUSTOM DOOR AND QUARTER
YT9 SPECIFIED, DIVISION INSTALLED (FISHER)
Z31 IDENTIFICATION PRICE SHEET ADVANCE
Z49 EXPORT, CANADIAN MODIF MANDATORY BASE EQUIPMENT
1SC VALUE OPTION PACKAGE
19U PRIMARY COLOR, EXTERIOR, LAMP BLACK
6YX SPRING, LH FRONT
7YW SPRING, RH FRONT
8PZ SPRING, LH REAR
82C TRIM COMBINATION, CLOTH, MED DK GRAY
82I INTERIOR TRIM, MED DK GRAY
829 SEAT BELT COLOR - MED DK GRAY
9SJ SPRING, RH REAR
Thanks for everyones help. This info should be more than enough help!!
Ram
