When you replace the rear main/front seal on your GN/TR do you use rtv sealent on the pan gasket? I bought a Fel Pro "rubber " pan gasket and was thinking of using a small bead of anabolic sealent on the gasket between it and the block as added insurance against leakage......Also, when I removed the pan bolts the 6 bolts at the rear and the corners were very loose.....do you guys use thread lock on the pan bolts??
Hey Eddie, I'm going to work on the GN tonight!! LOL
Woody
Woody
