runing braided larger fuel lines
karolko
i was hoping some of you guys might shed some light as to which way you ran both your fuel feed and fuel return lines to your engine. i am planning on running a -10 in and -8 return.
Photos of routing would be awesome.
My main soncern or are that i am mostly baffled in is the area around the rear axle.
Please help
thanks
I ran mine between the frame and body going over the diff along the pass. side. #10 just fits. Sorry no pics.
I ran mine up on the driver's side. I'll see if I can dig up some pics.
What are doing for a fuel tank and pump?
Billy T.
gnxtc2@aol.com
i am making a custom fuel cell that will sit under the floor pan of the trunk ( exactly where the original one sat) i am going to be running a magnafuel external pump attached to the drivers side frame rail. i cannot run it inside the frame bacause i am alos going to notch the frame, so that is a no go.
thanks
If you locate the fuel cell on the bottom of the trunk, you need to build a box around it with a bottom to be NHRA legal.:)
i am not worried about being nhra legal, i want to pass tech inspection at the local track.
