That's a Mitsubishi application though, they did have issues with cartridge flooding and leaking in the beginning. AMS and Buschur Racing figured out the cure for the leaking.
I appreciate the kind words Doug.
I definitely don't know everything, I'll be the first to admit that. :redface: Heck I learn something new everyday when it comes to this stuff. I just know that 99% of the time, journal bearing turbos, whether they be in a Buick or whatever, typically can and do live with a -4 feed line.
Now, there are some examples where excessive oil volume can overcome the applications return line/configuration. I saw this alot when working with customers who were building their first turbo setup and were trying to do it on the cheap. Things like using the wrong types of fittings, (cast tight 90* bend style brass fittings vs proper smooth bend hose ends) and even the wrong line sizes. I even had a guy try to argue with me one time, saying that his -6 return line was enough on his PT101 with a -4 feed line.
High oil pressures can also cause the oil to back up inside the bearing housing, eventually leading to oil seal failure. This is why we don't want more than 80psi fed to the turbos' oil feed line.
There are differences between manufacturers' internal bearing clearances, as well as differences between their allowable tollerances on bearings and oil seals. Then there is the damage that can be cause by the smallest amount of particles/trash in the oil itself that can lead to premature oil seal failure. No one knows exactly why some turbos can live forever with a -4 line and some puke oil for days with the same -4 line. None of the turbo manufacturers real world test the units with pressurized oil to check for leaks before shipping the unit. The oil inside each unit, is simply there for ease of assembly on the assembly line when they are built. This is why I recommended to just try the -4 line first. If it pukes oil like there's no tomorrow, then you can try the restrictor fitting. But honestly, if it was mine and it puked oil on start up, I would contact the turbo vendor direct and handle it accordingly. Stuff happens. Namely UPS gorillas throwing your precious and expensive turbo around before you even get it.
Just remember, it takes very little trash and or material to cause damage too the rotating assemblies internal parts at 130k rpms.
Honestly, this is a debate that can go on forever. Sure would be nice if we could get one of Garrett's engineers to post their official word on this. Where is Timo when we need him?
HTH
Patrick
