I've recently come into ownership of a 1972 442 W-30 code with the 455 CID... motor is a blown... and supercharged and doesn't run... the problem with this motor is to keep it alive it needs to be run very rich, but alcohol would save some streetability and give me the ability to run higher boost levels... SO the questions is would a nitrous plate flow enough alcohol? I figure I can plumb the line in, and have the amount of alcohol sprayed in metered by a tach... NO ALCOHOL below 2000RPM and then elevate up to 50% at 5000RPM... anyone heard of anybody running alcohol AND pump gas on a carb'd motor?
