running an fuel lines from the tank
boost jnky
my fuel lines from my tank to my fuel filter are bad. i want to run a an line from the tank to the filter as well as on the return. i think the person who owned the car before me has had a problem with the lines before cause the return line has a break in it at about the same spot as the fuel filter, its just on the passenger side. anyway i was wondering if anybody esle has done this setup and what fittings did yall use to do this?
You can go two ways.
1. Buy S.S. replacement lines and simply replace the existing lines.
2. Buy #8 feed and #6 return Steel Braided lines.
The second option will require a little though on how you run the hose. From that you order what you need and run the hose to and from the engine. Be careful when you get to the tank. Be sure to have secure connections.
Hope this helps you.
