WARBIRD1989
- Jul 25, 2004
SignUp Now!MAF controls injector duty cycle as well. If your MAF only goes to 150 at WOT.. your going to lean out hard.
If your chip was burned for 16 PSI and you run 25 PSI.. then your going to be out of fuel as well.
If you have Direct Scan you can read injector duty cycle.
I have an issue a month ago I was losing fuel pressure.. ended up being a bad fuel pump relay.
So if your fuel pressure tracks PSI per PSI.. then its injectors not being told to open. MAF or Chip issue.
HTH
