I switched to my 65# injectors and the car runs totally different.
Got my base fuel table pretty close, minimal correction (under 3% pretty much everywhere I have played), now run it in open loop idle at Harry's suggestion, gonna bring the car to work and play with it on the dyno as driving around while looking at a laptop is kinda hazerdous
One thing the car exhibits, which I just cant seem to get rid of is a tip in sag or stumble. When you blip the throttle I get a vvvvahhvrooommmm. In my chip this was caused by insufficient TPS delta and I got rid of it, but there doesnt seem to be anything like this in the FAST box. I've tried AE v TPS, AE v TPS rate of change (this would seem to be delta no?), AE vs MAP, AE vs MAP rate of change, moving the VE boxes around in this operating range only make the car lean or fat, wont remove this stumble.
Is this something to do with the speed density software? I know this is common with MAF cars, but I thought the deal with speed density was they didnt have transport lag (time between MAF reading the extra airflow to the time the ECM richened the mixture) like a MAF car and wouldnt do this.
Its not only my car that does this either, I played with my buddy rich's program and his car did/does the same thing. I guess its something I gotta live with? Its not real bad, or annoying. The car doest backfire or sneeze when snapping the pedal, its just I'd like to get rid of this if it is possible.
Otherwise, idle is silky smooth at 850-900rpm, the fan doesnt make the car hiccup anymore, and putting it in gear feels like stock
Anyone successful getting the car to stop this and have a tip for me?
