just got this car recently and when i start it up it smells rich which i feel is normal for the chip thats in it, but after 5-7 min of idle time it starts smoking a whitish blueish and gray when i rev it a little, and the fumes and raw unburnt fuel will kill you in a matter of minutes, at first i was thinking oil from exhaust side of turbo but want to rule that out for now, im wondering if the 02 is bad and the ecm is dumping fuel in to compensate, scanmaster milivolts were 525-710 at idle fully warmed up, blm was 130, so far i have checked for vacuum leaks and thats all good, no exhaust leaks, pcv valve ok and working, fuel press 43psi, checked intake and plenum bolts all are tight, also pulled plugs to inspect, they are very dark like a rich condition but no signs of oil on them, any ideas of where to look or check will be great.
mods are ta 49
TT93 alky chip
lt1 maf/translator
tr6 ignition
			mods are ta 49
TT93 alky chip
lt1 maf/translator
tr6 ignition
