B
Baron
Guest
Ok, so I just had $320.00 of work done (thermostat, waterpump, rotted out the radiator) done on my Buick ('81 4.1 v6) to fix the overheating problem that just sprang up, but I was informed that most likely I had a hole in a head gasket when they were all done with it and that would be like another $900. Well, I'm a poor kid and can't do that (I'm trying to sell it anyway, anythoughts on value for an '81 LeSabre that is in otherwise good condition). They told me to try some block sealer, which I am, but it still seems to be doing that. What it does is 1: Heat up really fast. It runs fine (well, it dies when I put it in gear right after I start it when it's cold unless i give it a bit of gas) until it warms up. 2: Once it's warm/hot it will die when I stop or start slowing down a lot unless I put it in neutral and give it some gas. 3: Once I park and open the hood, the water/antifreeze is basically boiling in the reserve tank.
Anyway, I wanted to see what some of y'all that actually know a lot about these engines thought and what my best course of action is to get it going and sold ASAP!
