maloneysforever
- Mar 16, 2008
I was wondering if anyone could point me in the right direction on this. I just got done doing some work to my 85 Grand National and when done the car runs like it has a miss and the tach is inop. Before I worked on it the tach worked (just replaced the part in the cluster this last summer) and it ran great. Here is a list of the things that I did.
Replaced valve cover gaskets.
replaced the wiring connector for the wastegate solanoid
fixed loose wires at the starter solanoid
replaced the negative battery cable
replaced the 2 dash speakers
installed missing light bulbs in the instrument cluster for the temp/volt lights
replaced light bulb for the heater control panel
I am hoping that someone could point me in the right direction of what I screwed up. I already checked to make sure that the firing order is correct.
