TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Slowly putting my GN back together with new SSBC calipers, rotors and Russell flexible lines. Not happy with how they connect to the factory frame brackets. They don't fit into the bracket like the factory ones do. Once you install the clip on the solid brake line side of the bracket the line can still move around. Am I the only having this problem?? Guess I will have to put a shim between the clip and the bracket to take up the slack?? Just sort of pisses me off that they don't put a little extra time into making sure these fit perfectly, especially since we are talking about brakes!
Also noticed that the bolt for the brake line at the caliper is now limited the ability of the steering to turn all the way. The bolt is actually hitting the frame at almost full turn. Now the suspension is dropping a bit due to the car being on jackstands so hopefully there will be clearance once it is back on the ground.
