s-10 blazer wheels
j-6
Will the stock blazer wheels work on a gn just for some slicks
I can tell you without a doubt that you couldn't use the wheels from a 4x4 Blazer. The backspacing is way different. As far as 2wd Blazer wheels go, I'm not sure if the bolt pattern and pilot bore are the same, or if the backspacing is correct for that matter. One thing I do know is most Blazer wheels are 15x7 so I'm not sure why you'd want to use them instead of a wider wheel for slicks? This of course does not count the wheels that came on Blazers with the ZQ8 (Xtreme) suspension package which are 16x8s. I think the Sy/Ty wheels are 16x8s if I'm not mistaken too but their backspacing wouldn't work. HTH
A friend of mine used s10 blazer wheels from a 89-94 blazer and they fit nice. You have to go with the 2wd wheels though. The guy in the previous post was right, the 4x4 wheels will not fit. Now if this is the case, I would assume that 2wd s10 pickup wheels along with the 82-87 BASE model camaro will also fit. Not the RS but the one they made that was below that one, the one without the ground effects. All of those cars I believe had the same backspacing.
My son put my 87 Ttype wheels on his 95 Jimmy with no issues. It looks good. I had to go to 84/85 Gn wheels to get backspace to clear 12" Baer brakes.
