S-hose from intake to waterpump
Jims project
Jims project
getting ready to swap things over to other motor and noticed that there is no outlet coming from the top of the waterpump, it looks like just a casting nub? the outlet is there from the intake,,so now what? this isn't common is it. any suggestions..thanks again
Intake S hose goes to the timing cover behind the water pump, the water pump line goes to the pipe that runs to the heater core.
right, but there isn't a nipple for it to go on the timing cover..there's no provisions for the hose
right...but there isn't a nipple for the hose to slip over on the timing cover,,it's just a solid piece of alum. casting
Look like this?
I cut my nipple off (ouch!), tapped it for a 1/4" NPT plug and never looked back...
yes it does, so what did you do about the intake nipple? does it effect the cooling? so i assume its ok to run that way?
