- Jun 18, 2001
I am going to sell my back up stage 2 short block. I will sell the motor completely fresh with new rings, bearing etc. I have cams and pistons for either a S2 heads or production heads and will build it for your needs. Both cams are DLS grinds and will include timing chain and cam nose hardware. Both pistons will be in the 9:1 range for compression with a 48-50cc chamber. Block is a 153 on center with a 4" bore and std deck height. One bore has a sleeve from a scored cyl from faulty ring installation so the cyl was sleeved instead of boring the others out. The block has never been damaged or cracked and was a new block prior to being machined for a turbo car. The block deck surface is o-ringed and I will include a new set of SCE titan headgaskets. The crank is a 3.625 Moldex BMS forging that was cut for this setup and was never in a roundy round car. Rods are carrillos and again were purchased new for this build and have little use. I will also include the front cover with duttwieller oil pump and the AN lines for the pump. I will also include the Billet Fab sheetmetal oil pan and solid motor mounts. This will be a complete short block ready for your heads. This motor has been 8.30's with S2 heads and 8.70's with production heads so it is a well proven piece. Again it will be completely freshened and ready to go. Will also include fluidampr balancer and mondello flexplate. $7500 obo.
I am also going to be selling the CAS sheetmetal intake I have on my car now. Intake has been 8.55@162.45 and EGT's are less than 80* difference from the lowest to the highest cylinder. Intake is powder coated with black texture finish and looks good. Intake is complete with fuel rails and all the necessary tabs etc to bolt onto any turbo car. It is for an on center block. $1000
Call or e-mail if interested
330-559-6552
mlyonsdc@yahoo.com
330-559-6552
mlyonsdc@yahoo.com
