Sat Oct 11th TB parts swap meet @ Spoolfool's.
Looking forward to this! I'm bringing a set of Hotchkiss sport front and rear bars, rear cargo springs, SMC alcohol injection (newer style), 60lb injectors, stock fuel rail with good adjustable regulator.
Not bringing, but I have a 6.0 LS block, .030 over, fresh LQ4 heads, just machined and never built. I have the rest of the complete engine, Tony.
Alright guys, here is a list of my crap I can bring if someone is interested:
CAN BRING:
STAGE II “.020 OVER” 153 BLOCK
STAGE II CRANK 3.59” CROWER BILLET
STAGE II CRANK 3.58” CROWER BILLET
ENTIRE ATR STAGE II TWIN TURBO SYSTEM (HEADERS, TURBOS, ALL PIPING, FILTERS, OIL LINES, ETC)
CHAPMAN STAGE II HEADS W/ JESEL’S (FRESH, READY TO RUN)
CHAPMAN STAGE II EFI INTAKE W/ RAILS
STAGE II HEADS, NEED FRESHENED
STAGE II 6.5” CROWER ON CENTER RODS (5 GOOD, ONE IS SLIGHTLY BENT)
STAGE II FRONT COVER
6.0 LQ9 LONG BLOCK W/ ACCESSORIES AND BRACKETS
4.8 LS SHORT BLOCK
ATI TH400 W/ BRAKE, DEEP PAN, 8”, DS, ETC
MODIFIED ECM FOR HIGH/LOW Z INJECTORS, W/ POWERLOGGER
MSD BOOST CONTROLLER W/CO2 BOTTLE, SOLENOIDS, ETC
GN REAR BUMPER (NICE)
WELD DRAG LITE WHEELS/TIRES 15X7 AND 15X8
S&W 10PT ROLL CAGE KIT
COMPETITION ENGINEERING REAR SWAY BAR (WELD IN TYPE, VERY NICE)
15 GAL ALUM FUEL CELL, BRAND NEW, W/ SENDER. POWDER COATED BLACK
F-BODY RADIATOR
HUGE! REAR SWAY BAR & MATCHING TUBULAR LCA’S (MATCHED SET)
SOUTH SIDE MACHINE LIFT BARS
STOCK REAR SWAY BAR
ADJUSTABLE WASTEGATE ACTUATOR (FOR STOCK TURBO)
BOXED STOCK UCA’S/ LCA’S (NEW POLY BUSHING, PLUS BUSHINGS FOR UPPERS, AND REAR DIFF)
BOXED STOCK UCA’S/ LCA’S (NO BUSHINGS)
STOCK IC, SHROUD & SCREEN
2 SETS OF BACK SEAT BRACES
FRONT “MONTE CARLO” BRACES? ONES THAT GO FROM FRAME RAILS TO “HORN” UNDER ENGINE
STOCK ROCKER ARMS & SHAFTS
ATR AIR CAN FOR COLD AIR SETUP
STOCK IC FAN
STOCK RAD FAN FOR PARTS (MOTOR GOOD, FAN GOOD, SHROUD MOUNT TABS BROKEN)
LOOKING FOR (and prefer to trade for):
XFI/XIM
ALRADCO RADIATOR AND FANS
SPOOLFOOL FILLERS
LARGE 4 BOLT TURBO (42/76-ISH)
HYDROBOOST LINES, POWER STEERING PUMP, BRACKETS, ETC (I HAVE THE MASTER AND BOOST UNIT)
HEAT/AC BOX, AC LINES, AC COMPRESSOR
GEAR VENDOR FOR TH400
NICE HEADLINER
DOOR DEW SWEEPS
MANUAL BOOST CONTROLLER
NEW FRONT COVER
TA/DUTT OIL PUMP
RJC PULLEYS
NICE SPEAKERS FOR CSII DOORS, DASH, AND REAR
CARPETED TRUNK KIT
MAIN ENGINE ACCY BRACKET, ALT Y BRACKET, SMALL AC BRACKETS, ETC
NEW FRONT COIL SPRINGS (STOCK HEIGHT MOOGS, OR ~1” DROP)
NEW SEAT COVERS FRONT & REAR
RECARO SEATS
Or?????? Surprise me. :)
I got some moog front and rear springs used not sure on the mileage but I redid my suspension so I swapped them out but if you need them I'll let them go for 40 for both ...
I'm in guys gonna bring a few stock goodies
Stock springs front and rear
Stock radiator top plate
Radiator overflow bottle
Windshield overflow bottle
Front support braces fender to core
And firewall to core
5 piece rear spoiler
Billet horn ring
Stock turbo cover
Rear sway bar (Ludwig)
Stock inter cooler
As long as it's not gouged up or scratched up or bent I am interested. PM me how much please, or let me know if you see any of my crap you want in return. :)
Damn!
Hey Squid, I think it might be the raw, unpolished one........... from Kirbans.... :eek::D:D:D:D
Whoa, whoa, whoa... No such thing as too much coffee! I probably drank a 55 gallon drum worth these past 4 days... So glad to be home!
