Scan master numbers
Put it on that and went for a test drive and now the car won't go into drive.. Gonna have to dive into that and see what's wrong.
86 Grand National, Hotwire kit, glowshift gauges, more asap.
Email Eric at Turbotweak your set up and he will burn you a chip that you need.
Ok i need help 87 GN stock motor and turbo. upgraded CAI, upgraded exhaust, 60 pound injectors, bigger fuel pump, turbo tweaks chip for 17 psi boost. Where should my scan numbers be at for WOT. running 13.74 @ 95 MPH Thanks.
Idle numbers
AF 05
L8 37
BAT 13.7
INT 128
BL 126
CLE 187
ATs 127
RPM 825
TPS .44
IAC 61
CC 81
well, i will thanks.
More people will see your post if you start your own, the only people that see this are the ones in this thread...its also called hijacking and you might not get a answer to your question....no disrespect Just letting you know how it sometimes works on the forums.
