czimpel
Boost...gotta get some!
- Aug 16, 2012
Just got my new Scanmaster hooked up tonight and was going through some of the setup and menus. I noticed that my TPS was low at idle(.38) and low at WOT (4.3) So I adjusted it a little and ended up with an idle reading of .46(should be .42 according to the instructions) and a 4.5 at WOT(should be 4.6-4.8)
Throttle is resting against the stop at idle and hitting the stop at WOT.
Do I have a bad TPS?
If I adjust higher the idle number is too high, if I drop the idle to .42 the WOT number is too low.
What do I do?
Also, I can't get to the injector pulse width or spark advance menu. Is this normal?
What do I do?
