TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Working on a project car. New scanmaster, powerlogger and PLX wideband. All wired correctly and scanmaster is not showing any wideband reading which should be the default display. Yes, scanmaster has 2.2 chip update. Running Turbo Tweak 6.1 alky chip for PLX wideband. MAF signal wire to #2 I/O terminal, scanmaster wire to #7 on I/O and wire from analog terminal on PLX to the correct terminal on I/O terminal. I did not run a ground from the analog plug as many have said not to. Any clues? Scanmaster is powered off the same ignition power wire so I know I have power and yes wideband is plugged in. ALL NEW Parts.
When I turn on key (not running) Scanmaster displays 2.2 and the PL 4.4 The setup in this car is identical to the one on my own GN so I wouldn't think I would need to update anything. The scanmaster options are all checked. HELP!
