scanmaster problem
86SS86LS
Scanmaster flashes 2.0 when I start the car and then the read-out is blank. I assume that I connected it to the ALDL wrong. I used a red spade, U shaped connector to attach the white wire to the E location (second from the right) in the ALDL. Any ideas?
The white wire should be connected to pin E, top row second from the left, you have it connected to pin B.
