Scanmaster readings are they good????
onefastgn
AF-- 04
L8-- 29-30
BAT-- 13.5
INT-- 128
BL-- 133
MPH-- 00
CLT-- 183
ATS-- 100-106
RPM-- 825-850
TPS--.42
IAC--20-22
CC--.05-220
MAL--00
85 degree outside. And had just drove it for an hour
It was at idle. I just installed 60lbs Injectors and a TT chip. Just wanted to get some feedback. Thanks Tony
For idleing
Those are textbook readings. You could not ask for better.
Now whats the WOT O2's and how much knock retard?
I only had 15 psi of boost, No knock and 02's were any where from 770 to 820 or so.The only thing that i noticed is only once the 02 showed 126 for some reason but only had 1.4 degree of knock. I'm not sure what happen. I was only using pump gas. I do have a single wire Denso 02 sensor that i will be installing when it shows up and a RJC stock power plate. After that i plan on getting some 1/4 mile times. I was only trying to stay in the 11's. Thanks for looking at the numbers guys.
