Scanmaster readings
87gnttop1
Af 03
L8 00
Bat 11.8
Int 128
Bl 128
Mph 00
Clt 121
Ats 51
R 000
Tps .40
Iac 150
Cc 00
Nal 00
The issue I'm having is that the car won't idle unless I unplug the tps it stays at about 2000rmp
I see that his display is obviously key on engine OFF!!! IAC is supposed to be 150, with key on engine OFF!!!!
well i had a issue with the car not idling i changed a bunch of parts it ended up being the fuel pump car started up stayed idling only if i unplug the tps i got 2 codes which was 22 and 24 im going to check the timing to make sure everything is ok but does anyone have any idea
