Scanmaster #'s Please check it out
turbotroy
Hey everyone, got my 60# injectors and TT 6.1 chip and ls1 maf and powerplate installed today. I think most of my numbers look pretty good except spark advance. If I try getting into boost, knock counts go nuts, even scanmaster isn't logging any retard, but reading it on pl. Anyway, thanks in advance guys, this site is a life saver! This was in idle after a 30 mile ride of city and freeway. When I figure how to post PL , I will.
WB02 16-17
AF 7
L8 42
BAT 13.4
INT 128
BL 131
MPH 0
CLT 200
ATS 160
RPM 925
TPS .46
IAC 00
CC 0-255
PU 2.3
SP 27.5 40+ at 70 mph
MAL 00
IAC is at zero. TPS is at .46 That's not bad but TT chip calls for .42 Get the IAC in check. The car seems to be running a little hot also.
Thanks for the replies. Started back on car this am and found gas running out of steel line before connector where it comes up in front of engine. Will correct iac and tps after fuel leak. How do ya keep this thing cool in southern AZ? I have 160° t-stat but radiator could be oem. Thanks
