Scanmaster - WB / KR
Jerryl
Tall Unvaccinated Chinese Guy
Is there a way to display wb/kr instead of nb/kr on scanmaster? Car has PL. :cool:
I believe so, I think AEM makes a harness that goes from the 02 direct to the Powerlogger. Other companies might too. I decided to have a gauge on the A pillar.
If you have powerlogger, you should have received the 2.2 update chip for the scanmaster. If you have your WB installed and sending it's analog signal to the powerlogger analog block input 1, then you're set.
All you have to do now is tell powerlogger to send the wb signal to the scanmaster, and you do that on the powerlogger F3 page lower left, scanmaster options button. I have all of them selected except display EGT.
Cool. Yeah, the 2.2 is installed. So you can display both wb and kr at the same time?
Don't forget, that's fast update so the numbers go pretty fast. It's not always easy to read, easier to just log.
