ScanMaster3
jdcfrank
Guess I had a loose connection all it showed was the first pic. Redid one of the wires now these are some of the reads I get at start up.
And this is in the car too.
I would double check the wire to the ECM harness, also check that you are in the prope spot on the ALDL connector
scanmaster 3 is for xfi/fast ..it doesnt support aldl data from a stock ecu
i went over this with him on may 2 in private conversation.
i jumped the gun ..thought this was a new post but its an old one that you brought to the top .
pretty sure he knows now that the car he bought the previous owner must have had a fast or XFI and changed it back to an ecm before selling but didnt remove the scanmaster3
Yup this is an old post. I swapped out the ScanMaster3 for the correct one. Installed a ScanMaster 2.1. Everything is working now. If I read it correctly I got error code 52, due the calpak missing as u told me.
