Search function???
Sleeper
Just bringing it over here... The search function isn't working, and hasn't been for a while. Can it be fixed?
Paul
Ha! I get the same feeling...
Sorry guys, but I have no idea what's going on with the search function. I've e-mailed our webmaster on it several times without a reply.
I'll give Bruce a call and see if he can do anything, or if he can find out what the problem is.
Thanks for the help Geoff. It seems like others have said it doesnt work when your car is broken.
thanks for the help,
Jason
alternative searching
Quiky One said:
Works if you type one word in.
Jason
You can also search from Yahoo! or Google just add site:www.turbobuick.com[/U] to any search and you'll get results. It may not be as good as searching on the site itself but it will give some results. I used this a lot when gnttype was down; I used google and then viewed the cached version. :biggrin:
Geoff must have made an impression. I too was getting ready to email our webmaster, because I attempted to search a string a word and it did not work. But this morning, the search function appears to be funtioning normally.
Looking for the link for power wheel upgrades, my neice and nephews are let down :confused:
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
Yeah, i kinda forgot who was doing it...
I couldnt use the search feature anyway..
Thanks again..
BW
