Selling out my spare engine stuff for hybrid
Bob- just confirmed you should have the funds for the turbo in your account.
Updated List
Precision TE44 turbo, good shape no end play. 350 SOLD
Stock turbo in good shape 175
Casper's wire harness for GN engine swap, never used. 200
Stock wire harness including interior. 300 or 200 for just engine harness
Ported iron heads, 1.77 valves, cut for wire lock o-ring headgaskets, LT1 springs for flat tappet cam 500
Terry Houston DP elbow for tight fit engine swap or cut it to fit your project 150
Stock exhaust manifolds and cross over 100
Complete intake upper and lower with injector harness 150
Power logger 150 SOLD
Motron 60lb injectors with less than 2 months use form Turbotweak 200
Inovative LC1 sensor and WB 175
TT SD2 chip for 60's and E85 150
RJC power plate 40
Coil pack, module and Magnacore wires, all worked great 125
Stock 109 short block with double roller timing chair and 206/206 flat tappet cam. Was running good before I stored it. I was going to put new bearings in it which I will throw in. 750
Updated List
RJC power plate 40
The claspers harness if for engine swap of GN motor into something other than a regal
Will take pictures if serious
I'm in on harness with PayPal ready. Just one pic would be good.
