Senders?
I'm putting a set of mechanical gauges in a 84 ttype wondering where you guys have the senders in the block for the coolant temp and oil pressure?
you can either remove the stock idiot light sender for the temp gauge or drill and tap another hole next to it. i'd suggest that you try to keep the idiot light, because it will alert you when something goes wrong faster than a gauge that you don't look at all the time.
you can put a "T" fitting where the oil pressure sender screws into the front of the engine and put the gauge there.
