Okay. I have a problem with an engine that I thought I had licked. It had melted a plug off in the engine, taking out a piston and a head. I ended up suspecting the injectors and had them flowed. That injector flowed almost 20% lower. So I thought I had found my problem. So we replaced the 75s with 85s. So I repair the damage and get the car going again. Short 3-5 second blast on the street, everything looked good. I started at 19 degrees spark, 18 psi, and 10.6 AFR. I crept up to 21 psi, 21 degrees, and 11.0 AFR (ALKY). EGT's were on the cold side, and no knock. Seemed safe enough to start tuning at the track.
So, first pass I blew an intercooler hose off about the 1000' mark and coast a 10.2 @ 121. I was quite optimistic. Unfortunately I forgot to arm the datalogger.
But I knew the tune was on the conservative side and o2 corrections were less than 1% previously.
So, I go to run it again after checking some stuff over. Then the same problem rears it's ugly head. EGT's were high 1300-low 1400's. Til about the middle of 3rd. Then #1 EGT skyrocketed. Did not percieve anything wrong during the run, but slowed to a 10.3x at 129. Checked the log, and knew something was wrong. It was adding fuel and the EGT rise made my stomach sink. Pulled the plug, and it was done. Dropped 50 psi compression on that hole.
It has a homemade double pumper with 2 -6 lines off each pump, Y'd to a -10, -6 return. Saginaw fittings cut off and AN fitting welded to the rail. Both pumps were flowed and were deemed good. FP is verified 1:1 rise, with 45 PSI static. It fueled my car to 141 MPH without alky and showed no signs of dropping off.
I am going crazy. Injector driver? Wiring? Injector harness ohms good, and pins look new. Have not checked the rest of the harness yet.
Anyways, look at the log and let me know what you think. I took up alot of slots with EGT on the dash. I wish I had some other things logged, but take a look and see if you can see anything wrong.
Combo:
109 stroker, 8.5:1
XFI
70 GTQ turbo
224/224 hydraulic roller
Race ported GN1's
Combo:
109 stroker, 8.5:1
XFI
70 GTQ turbo
Race ported GN1's
