servo clearance CK
SIXBANGR
mean old man
The stock piece is suppossed to have around .050 if i recall. How about the big CK servo, same as stock? And if so how do you make the adjustment? The stock ones we use to a use washer.
Band clearance spec .060" should be the same. Normally a longer Pin is used & the tip is ground for clearance.
