Servo modifications?
clusolynn
I was wondering...would it work, to fill the upper resevoir in a servo cover, the section outside the trans about the diameter of a silver dollar, if it were filled solid making less fill area, would the servo apply harder and quicker? The same amount of fluid and pressure going to a smaller area? Or, would it be too much fluid/pressure? Thanks, John.:cool:
It will do nothing but reduce the volume. The servo is the part with the lip seals on it. The surface area of that is what matters.
