luisturbog
UNDERDOG HOT AIR !!!!!!!
- Mar 30, 2007
For all the buick enthusiasts out there! Just wanted to let you guys know if you install a hitachi psl 100 in a hot air ( i don't know if intercooled is the same) you have to modify by cutting, or grinding the aluminum block closest to engine crank case. I just found out today when I installed it in my 84. Seems the crank case has some casting flash that is in the way, rather than mess with my block I cut the mounting block on the starter, being it can be replaced easier than the crank case. Thanks to all for great info! hope this helps somebody! good night.
