Setting cam sensor question!!!!!!
Thanks everyone for your help, it was my crank sensor I destroyed.
By the way, while the car is running can I adjust the cam sensor to see if I get a better idle or would this even have any effect?
6pack, might want to check the crank sensor. Make sure the balancer ring is going the first slot from the right if your looking from straight underneath the car.
Dannyo
Danster..
Mine is a timing problem as I have fuel, and spark. Also by the way the throttle body shot fire at me :eek: the other day I would say mine is timing. Gonna fool with it some more this weekend. Good to hear you solved your problem!;)
Dannyo
Sometimes, turning the sensor about an 1/8"-3/16" further ccw appears to make them run better. It may affect the fueling when you do this. Opinions vary but observed results suggest that something changes.
