Hi I have an 84 stock hot air car. A friend and I were resetting the minimum air then the TPS. For some reason we still have a slight stumble when I take off in the car in drive after a cold start. This seems to never go away no matter what we do. I will admit we've been using my friends experience to guess the engine is around 500 rpm
He's pretty accurate.
I wonder if we are off by 75 rpms would that make that much of a difference? My 84 service manual says to set at 500 +/- 50.
Is there a procedure to set the idle with the AC on? Now when I turn the AC off in PARK the car immediately dies!
