First of all i would like to let everyone know that as of August 1st i will be sending out monthly newsletters. These letters will include monthly sales, seturbo news, and everything else you dont want to miss
Just click here
info@seturbo.com
and type news, and ill add you to the list with your email address.
Wouldnt you like to be able to control your boost pressure from inside your car? Well weve get just the thing, seturbo manual adjustible boost valves, and bleeder valves. These are brand new items and are on sell right now!!
1. MANUAL ADJ. BOOST VALVE $45.00
Seturbo large needle valve with 1/4 steel body, color coded shaft numbered 0-9. Includes 2-1/4" Brass Barbs
http://www.seturbo.com/cat-buick/images/data/TURBWAST1400.JPG
2. Seturbo Manual Adjustible Bleed Valve Boost Controller $39.95
Pneumatic needle valve composite housing material, calibrated adjustment knob, micrometered color coded shaft, Red locking ring, threaded for panel mounting. Includes 2-1/4" Brass Barbs.
http://www.seturbo.com/cat-buick/images/data/TURBWAST1300.JPG
3. Seturbo Brass Manual Adjustible Bleed Valve Boost Controller $39.95
Brass needle valve with 1/8" ports with 2-1/8" 27 NPTF barbs. Color coded shaft with numbered 0-9 adjustments knob.
http://www.seturbo.com/cat-buick/images/data/TURBWAST1200.JPG
4. Seturbo hybrid adjustible boost controller. $49.99
This is NOT a bleed valve, it is a pressure-controlled check valve which holds any boost from reacing and prematurely opening the wastegate before the desired engine boost level is achieved. Once the turbo spools up to the desired boost, the valve opens.
http://www.seturbo.com/cat-buick/images/data/TURBWAST1500.JPG
Heres a couple of other things we have for sell to the TB community
Full a-pillar dual pod gauge holders- $60
http://www.seturbo.com/cat-buick/images/data/dualpod.bmp
Full a-pillar Triple pod gauge holders- $70
http://www.seturbo.com/cat-buick/images/data/TRIGAUG.jpg
High-Torque mini-starters- $80
Chrome moly flexplates- $199
http://www.seturbo.com/cat-buick/images/data/TRANSPTS0082.jpg
PTS Xtreme Aluminum Shallow Pan- $275.00
http://www.seturbo.com/cat-buick/images/data/TRANSPTS0035.jpg
PTS Xtreme Aluminum Deep Pan- $275.00
Seturbo Boost Line Kits- $21.00
http://www.seturbo.com/cat-buick/images/data/TURBHOSKIT25525576.bmp
Custom Embroidard Hood Insulators- $150.00
http://www.seturbo.com/cat-buick/images/data/hoodins.jpg
Comp Roller Cam- $869.00
http://www.seturbo.com/cat-buick/images/data/COMP ROLLER CAM.JPG
Presicion Stock Appearing Intercooler- $760.00
http://www.seturbo.com/cat-buick/images/data/PTEINTER.JPG
Chrom 120 Amp Alternator (show quality)- $275.00
http://www.seturbo.com/cat-buick/images/data/CRM1000.jpg
Custom Embroidard Monogramed Floor Mats- $80.00
http://www.seturbo.com/cat-buick/images/data/CRMMAT1003.jpg
IAC Adapter Plate- $69.95
http://www.seturbo.com/cat-buick/images/data/ENGIAC1100.jpg
All the gaskets your little heart desires
http://www.seturbo.com/cat-buick/catalog2.php?cate_id=21&main_cat=8
Turbo Savers- $160.00
Well thats it for sales right now, but check out the website for everything else. www.seturbo.com
And we're also on Ebay now
And lastly i would like to personally thank all of our loyal customers for the positive support they've showed us here on the forums :redface:
Travis-
Just click here
info@seturbo.com
Travis-
