Southeast Turbo Performance would like to thank everyone for a great year!!
We've decided to have a giant end of year sale so make your Christmas list out now
For pictures of items visit
www.seturbo.com
Turbos:
All Turbos Include Actuator
1.
TA-49
$700.00
Stock appearing
3 bolt turbo
58mm compressor wheel
Stock or blue top injectors
stock or minimum stall converter
Flows 800 cfm
545 HP
High 11s
This is the most popular upgrade for the turbo regal. It looks exactly like a stock turbo, except the larger inlet bell, and will go deep into the 11's with the right combo.
2.
TE-44
$705.00
Non-stock appearing
3 bolt turbo
Flows 850 cfm
580 HP
Mid 11s
Very similar to the TA-49 only not stock appearing.
3.
TE-45A
$1100.00
Non-stock appearing
3 bolt turbo
63mm compressor wheel
009- 55# injectors
3200 stall converter
P trim turbine
Flows 950 cfm
680 HP
High 10s
I have this turbo on my car right now. It pulls like mad and has very little lag. You need a good 3200 convertor for this turbo.It utilizes the "big bearing" design, and has a full P-trim turbine wheel.
4.
TA64C
$1000.00
MID-10 SECOND
MIN STALL 3300
MAX HP 680
5.
LT72 Q-TRIM
$1500.00
Intercoolers:
1. Precision Stretch Location Intercooler
780HP
$765
2. Precision Front Mount Intercooler
$895
950HP
3. Southeast Turbo Xtreme Intercooler
1400+HP
$1400
Interior Items:
1. Custom Monogrammed Floor Carpets
(available in many designs)
$79.99
2. Custom Molded Floor Carpet
OEM molded floor carpet
$140.00
3. Dual Gauge Pod
$55.00
4. Triple Gauge Pod
$60.00
Exterior Items:
1. Bumper Fillers(full set)
$249.99
2. Smoked Headlight Covers
$55.00
3. Blackout Tail Light Covers
$55.00
4. Aluminum Front or Rear Bumper Struts
$60.00(pair)
Misc.
1. Chrome Moly Flexplate
$199.00
SFI certified flexplate required when a vehicle runs:
11.99 or quicker 1/4
7.49 or quicker 1/8
or over 135 MPH
2. Air Bags
$79.00
Air bags help reduce squat and helps plant the right rear wheel. Air bags allow you to adjust the suspension by changing air pressure independently between both sides.
3. Metco Lower Control Arms
$290.00
4. High-Torque Mini Starter
Loose 9 Pounds
$90.00
Happy Holidays from everyone at
www.seturbo.com
Turbos:
1.
TA-49
$700.00
Stock appearing
3 bolt turbo
Flows 800 cfm
545 HP
High 11s
2.
TE-44
$705.00
Non-stock appearing
3 bolt turbo
Flows 850 cfm
580 HP
Mid 11s
3.
TE-45A
$1100.00
Non-stock appearing
3 bolt turbo
009- 55# injectors
P trim turbine
Flows 950 cfm
680 HP
High 10s
4.
TA64C
$1000.00
MID-10 SECOND
MIN STALL 3300
MAX HP 680
5.
LT72 Q-TRIM
$1500.00
Intercoolers:
780HP
$765
$895
950HP
1400+HP
$1400
Interior Items:
$79.99
$140.00
3. Dual Gauge Pod
$55.00
4. Triple Gauge Pod
$60.00
Exterior Items:
$249.99
$55.00
$55.00
$60.00(pair)
Misc.
$199.00
7.49 or quicker 1/8
or over 135 MPH
2. Air Bags
$79.00
$290.00
Loose 9 Pounds
$90.00
