Shift Kit Install Questions
rc1626
Installing a P.T.S. shift kit and am in need of some help with accumulator locations. I'm assuming the 3-4 accumulator is next to the valve body with the 4th being between the plate and the case????? 3rd would be below that and 2nd would be on the passanger side of the tranny next to the cat convertor.?????Any info would be greatly appreciated.
Thanks!
Rob
3-4 accumulator is in the case. 2nd is in the housing next to the valve body. Drawing is "as installed in vehicle" with 2nd accumulator housing below separator plate. 2nd piston is
actually much longer below sealing ring than depicted in drawing.
I also sent you a copy of the set-up page via e-mail. I hope this helps. :)
