My 87 T type which I bought new has 106,000 klms and has lead a fairly easy life (i.e.; no racing) just some infrequent quick acceleration episodes. It has developed a transmission problem in that it shifts normally out of 1st with normal light throttle but rapidly shifts right into 3rd after the 2nd shift. It does this more aggressively when it is at operating temp. I have to give it a lot of gas pedal to get it to shift back down to have it have any sense of power. I did try to shorten the throttle cable on notch which made a bit of improvement in the shift pattern but the lockup wouldn't come on at speed up to at least 110 klm per hour. I am wary about taking to any of our local trans shops without having some idea of what might be causing it. From reading this forum I know that some of the original gm performance upgrade parts are no longer available from GM so was also wondering if any of the forum venders have suitable replacement parts if needed. I am located in BC Canada. Maybe the trans shifting problem is related to another non transmission part failure??? Thanks for any and all suggestions as to how this is happening. Leon
