shifter indicator light displays lights on natural and overdrive at the same time
GNONYX
Hi All,
Is there a way to adjust the shifter indicator light so only the neutral or overdrive indicator light displays with only ONE indicator light being lit?
your indicator light plate under the shift slide ...might be messed up or broke ...there is little plastic squares on the plate ...one might have broke allowing light into two areas ...
The bulb/wire to it can come loose as well. I was able to access ours and fix this same issue by placing my hand held work light upside down toward rear of the console supporting it and pointing toward the front of the console.
From the back seat area i could reach all bulbs and wires to re-stick them and tape them back in place. I did remove shifter handle but not sure I had to after accessing the area from behind the drivers seat.
Today I removed the shifter top plate and saw the bulb was not secure into the socket.
I might have disturbed the sifter light as I was replacing the shifter cable.
In a couple of days I will readjust the shifter cable linkage again
Thanks everyone for your inputs
