Shifting problem Manual only
smoke20
So I have not rebuilt a ton of these did 3 this week all same parts, but one is giving me trouble
Customer did valve body (shift kit) himself is it done right ? can it cause problem? He also has a diffrent manual valve in it?
Has hurst lighting rods in car, took aprart due to input drum clutches WELDED together 2nd time in 1200 miles Replaced drum, and ALL outher clutchs smoked bad
this is his problem! car shifts fine in drive/overdrive ( will shift threw all gears) will not shift at all, shifting it manually. I am lost had it apart twice can not see anything....
Outher 2 I did, work perfect no problems shift hard as hell and shifts manually two.
what could it be???????? any help I thank you in advance
