TurboTnZ06
Go on red!
- May 7, 2002
Weldon 2015 Upgrade
Goals: Streetable, use factory tank, one fuel pump, support 9’s+ on race gas, using factory fuel rail without welding, and use the factory size regulator. Will this work? What am I missing? I’m doing -8 for feed and return just so it’s all the same size, even if the return is larger than needed. Is the factory size regulator going to be too restrictive on the return?
RobbMC stock tank pickup with -8AN male ends on feed and return
RobbMc Performance Products - GM 1/2" Sending Unit
$220
Weldon 2015 with -8AN in and out
$600-700
Weldon filter
$120
Weldon Dialaflow 14000
$400
40ft -8AN hose for feed and return- Teflon lined to reduce gas smell in garage
Aeroquip FCC0820 - Aeroquip TFE Racing Hose - Overview - SummitRacing.com
$270
Hose end fittings – female -8AN swivel
Need 7 to handle tank to filter, filter to pump, pump to fuel rail, fuel rail to tank return (return on regulator we’ll use a 90 fitting).
Aeroquip FBM4413 - Aeroquip Reusable Hose Ends - Overview - SummitRacing.com
$70
Regulator 90* bend to fuel line return, -8AN swivel
Aeroquip FBM4433 - Aeroquip Reusable Hose Ends - Overview - SummitRacing.com
$22
-8AN Unions to go into the pump and filter to have hoses attach to
4 of these needed
JEGS 110203 JEGS AN Reducer Fittings & Union Adapters
$20
20 Hose cushion clams
JEGS 82038 JEGS Cushion Clamps - Stainless Steel
$20
Fuel rail inlet adapter 16mm x 1.5 to -8AN
Earl s Performance 9919EFJERL - Earl's Performance AN to Metric Adapter Fittings - Overview - SummitRacing.com
$7
Turbofabricator link to 5/8 dowty seal 178110ERL with above mentioned shortened 9919EFJERL
http://www.turbobuick.com/forums/ge...2-fuel-rail-thread-size-ground-bolt-size.html
Earl's 178110 Earl's Specialty Fittings
$12
Regulator return adapter 14mm x 1.5 to -8AN
Earl's 9919EFH Earl's Metric Thread to AN Adapters
$12
Shipping- $30?
Total: $1903
$220
$600-700
Weldon filter
$120
$400
$270
$70
$22
4 of these needed
$20
$20
$7
$12
$12
Shipping- $30?
Total: $1903
